It would be easier to buff the car with a rotary buffer at 200 RPM to 400 RPM (very slow) with a Meguiars w-7000 series foam pad and Adam's machine Polish and then a w-9000 series buff pad with the same polish and intermitent sprays of Adam's or any other detail spray until the product breaks down.
Wash and detail with Adams or Meguiars glaze.
That way the swirls and defects are removed rather than applying multiple coats of a cover up topical that has to be done regularly. You have to use Zaino detail or a glaze every week or so to get the POP so why not just do it right.
Talk to any detailer or custom paint shop. i doubt any will advise the use of Zaino. My car looks crystal clear and Pops. I would compare it to any zaino car.
Also, go online and read some of the comparisons between Zaino and other topicals. Zaino is very controversial and no better in most comparisons than wipe-on wipe-off waxes or topicals.
If your car is trashed and can't be buffed to a gloss because of a bad paint job or clear coat then maybe Zaino is the way to go. But, adding layer after layer after layer on a good clear coat is just a build up which will have to be done again and again. Just my opinion from 40 years of painting and detailing.
Tom
I miss my Tazer
