Old 10-24-2010, 10:16 PM
lal Naja's Avatar
lal Naja lal Naja is offline
Cobra Make, Engine: Butler Cobra. 350 Chevy Engine, blueprinted, heads cc'd, ported, polished, manifolds matched, big valves, 1.6 roller rockers, TB Injected, mild cam, MSD crank trigger electronic ignition. TKO-600 transmission. XKE Jaguar rear. IFS by Fast Cars
Could be getting a little tight for 325/50/15 = 27.79" Diameter. I've got 295/50/15 = 26.61" Diameter. If your IRS is installed in the standard location you may face a space problem as the larger tire is 1 3/16" larger in diameter and that will tighten the space towards the front of the wheel arch by almost 5/8".
I moved my IRS backward 3/4 of an inch in the event that I have to fit a larger diameter tire.
The width may not be too much of a problem. You may have to adjust back spacing with a spacer, or have custom rims made if you have to move inward.
Arthur
