Old 01-14-2002, 01:50 PM
bkozlow bkozlow is offline
Cobra Make, Engine: built the molds and body composite construction
Hi,
Why are you drilling these bolts? Drilled bolts are generally available from sources such as Aircraft Spruce etc. If they are head bolts , why aren't you using studs? Also, the drilling operation on AN type bolts is usually done wbefore they are heat treated. I question the amount of heat you are generating in your drilling actually weakening the bolt. Just my thoughts.
bkozlow
