Originally Posted by RodKnock
OK, so Fram and K&N suck, and now the micron rating of the FL1A HP is too high. What are we left with to use? Just the FL1A, Wix and Moroso?
Was in Wally World the other day getting
oil and filter for my 05 Super Duty diesel truck....Guess what I found??????????
I always open the
oil filter box and make sure it is the correct filter in the correct box before going to the checkout and what I found was the Fram filter and Ford Motorcraft filter for my truck looked exactly identical, so I turned them over and they both had the exact same numbers on the bottom and same markings on the top, only exception was the Ford filter had a Ford stamp on it and Fram had a Fram stamp on it!!!!!!!!!!!
Otherwise, the EXACT same filter with the EXACT same numbers/markings,including the same part numbers and same patent numbers!!!!!!!!!!!!!!!!!!!!!!
About a $1.50 more for the Ford filter......
Now which filter is better?????????
They are the same exact filter!!!!!!!!!!!!! other than the Fram/Ford stamping and the box they were in, they ARE the same exact filter!!!!!!!!!!!!!!!
David
