Originally Posted by madmaxx
Not to highjack thread but Filtermag if you can afford is incredibly strong. The problem with magnets on the oil pan is you have to remove the pan to clean. The drain plug magnets are a joke.
The smaller the particle the stronger the magnet has to be. I beleive the filtermag has a heavy duty, the one that would fit an fl-1a that cost $69 and has an advertised 600lb pull!!!!!!!! Sheet it may collapse the oil filter, LOL!!!
Which Filtermag part number fits the FL-1a/FL-1HP?
Edit: So it seems that either one of these should fit:
300lbs pulling power:
http://www.summitracing.com/parts/FTM-SS375/ ($46)
600lbs pulling power:
http://www.summitracing.com/parts/FTM-RA365/ ($69)
So if you did it, does the extra 300lbs really make a difference on the heavy duty version or is the standard 300lbs version more than enough? For me it's less the extra $23 than it is the red color of the heavy duty version vs the black version of the standard version. I'm not a big fan of anything red or colored in my engine compartment.
www.partskeeper.com
