  #62 (permalink)
Old 10-28-2010, 09:02 AM
madmaxx madmaxx is offline
Need to edit post AGAIN due to bad information. The melling 10833M83HV is good to 8 gpm at 4000 rpm where I was TOLD it levels off. Earlier I was given bad info of 3.25 gpm. On a side not you can run it as high as 80 psig without issue. Even at 8 gpm the RP is less the 2PSIGD at operating temp. I hope it gets to about 50f tonight so I can thicken the oil up some.
As far as which filter is best, the ones with clean bypass, the ones with micron ratings in the 20's, the largest filter you can fit on your car, and the ones painted purple.
You guys wanted it so I am doing it, I am going back to drinking all next week in my carrabein resort. Last time I gained 8lbs!!!!!!
