01-14-2002, 08:28 PM
NH
Just drill it!
Some good ideas allready posted. The originals were drilled and lock wired but you probably don't want the taper lock bolts for your application. I have found a cheapo carbon steel drill bit is hard (also brittle) but works quite well. Wear your safety glasses and keep just enough pressure on the drill to make a chip.
Good luck
Cheers Nick
