Hi Bob I saw that nasty six at run and gun. Gald it was not in my class of pure street. On to clutches, have you talked to Red about the soft loc clutch a couple of guys are using them for racing It is a slipper type clutch. Leave the start line at 5000 rpm and the clutch is adjustable for the lock up, it leave like an automatic with a trans brake. It does not blow the tires off, and the shock to the drive train is gentler. FE motor cost 1400.00$ Once it is set up to leave you can adjust the lock up of the clutch at the higher rpm. he has a 25 page sheet how to set it up. He says it is good for 1/2 to 3/4 of a second in the quarter mile. Two cobras that go to Run&Gun use this clutch and back up the results. I can not tell you who because a promised the drivers. I am going to put one in my car when I get my G-Force trans. Hey Bob Have you tryed a bigger carb on that monster motor yet like a 1200cfm holley, only kidding
Talk to you soon Hope you are well Rick Lake
