Old 11-04-2010, 06:51 AM
tcrist tcrist is offline
Check your grounds. You do not say if this is a new build or not. If it is a new build and you painted things, you could have paint at the ground connection areas on the frame. If it has been built for a while, you could have corrosion between the ground areas. I would check those areas first.
Terry
"I may be paranoid, but that doesn't mean they are not watching me"
