Originally Posted by Excaliber
Virtually ALL standard transmission cars will grind in reverse if you shift there without hesitating after you put the clutch in. I shift into 4th first, THEN into reverse, it never grinds that way. Of course the reason is, reverse doesn't utilize synchro's like the forward gears do.
Thanks, that helps me.
Now does someone know where I can get a proper connector for the TKO neutral safety start pins? The ones that I have on there, usually act up after 3-4 months, especially when the engine gets hot. I then have to pop the hood and jumper the pins on the harness.
It looks like it should have a round connector with two pin push-on harness, with a beveled plastic ridge to snap on to the transmission.
