Originally Posted by mickmate
There are two separate lines and a tee. One line goes from low pickup in tank through trunk and electrics to a tee right after the mechanical pump. The other goes to the mechanical pump. They both run along the drivers side as that's where the mechanical is.
So you have two pickups coming out of the tank (2 separate that tee's back to one up at the front) or just one that is split into two and then tee's back together( one going to electric and one to mechanical) ?
Kids in the backseats cause accidents, accidents in the backseat causes kids ! Good reason to get a Cobra !!!
