Sambo, I would not be suprised if all manufacturers (kit suppliers) make the mounting area smaller than the screen gaps.
When I was building mine, I fitted the body central on chassis, then mounted the dash brace to the chassis and found that when I cut my holes for screen legs, that there was a gap on either side.
From memory I had to make a 12mm spacer on R/H side and a 16mm spacer on L/H side to get screen mounted central.
Cruising in 5th
