$23K??? Wow, the Roush name sure carries a premium!
This is likely the result of improper (low) torque on the nut, which allowed it to back-off and then the shaft snapped due to excessive deflection at the stress-riser (hole). In-spite of many 'experts' guidance your may recieve, including those from Roush, a properly torqued fastener will not back-off in this application. If they did, we'd never keep main caps attached to blocks or head bolts in heads. This has all the signs of improper assembly.
E. Wood
ItBites
10.69 @ 129.83mph - on pump gas and street tires
