Old 11-10-2010, 08:53 AM
Wbulk's Avatar
Wbulk Wbulk is offline
Cobra Make, Engine: 66 Cobra
I have done more research on the issue since I first brought this up and found that the part is called Lucas Bullet Connector. On some UK forum sites I read the debates on how to connect the wires. It appears there are different types of bullets, copper and brass. With a special crimping tools the copper ones can be crimped with the wire in the end. This is not your normal crimping tool. With the brass bullets the wire is soldiered in the end. I guess you could soldier the copper one to if you needed to. Dialectric grease was highly recommended.
