Thread: Chrysler Rant
Old 11-13-2010, 07:48 PM
SP01715's Avatar
SP01715 SP01715 is offline
Cobra Make, Engine: SPF1715, Roush Built 434 ci Stroker, Dart Block, Ported AFR 205 Heads... 561 hp / 547 tq, Former Roush Show Car, Completed and Prepped By Olthoff Racing.
Originally Posted by tcrist View Post
What did your closer dealer and the off road shop say caused the issue? The body or the suspension lift.
The body lift is causing the above problems. We are installing a 1" motor mount lift, and the correct drive shaft so the driveline can be lifted back up into the correct position. This will take car of the fan problem and transfer case shifting problem.
While we were inspecting everything we also noticed some things about the suspension lift that were not installed right. I am removing everything and going with a Rubicon Express long arm kit. I am running a similar set-up on my other jeep at it works very well.
I don't think the selling dealer even looked at anything. They saw 9200 miles on the odometer, and just checked off the certification list.
