Old 11-13-2010, 08:51 PM
The basic wiring looks like it should work. Assuming... The positive wire resting on the top of the pos terminal of the battery is actually getting a good connection, it doesn't look like a good connection. Did you use a meter to verify 12 volts at the two coil terminals?
If so, then a sharp and sudden break of the negative connection at the battery terminal should result in spark.
