Old 11-13-2010, 10:31 PM
Ralphy's Avatar
Ralphy Ralphy is offline
Default Thermal Engine Coatings
A question for you engine builders. Reading here that with running aluminum heads, you can run higher compression ratios. If you were to thermal coat your heads, pistons, valve stems and ports. Can you run an even higher compression ratio? This would be with pump gas.
Ralphy
