Originally Posted by MattM
You will have to install a relay for the fan switch to make the switch light up properly because the original switch only provides a ground to turn on the fan and the light in the new switch requires positive power to illuminate it. Thanks
MattM,
Is the relay is required only if you want the switches to light up when the headlights are on? I'm only looking for the switches to light up only when flipped in the "on" position.
