Old 11-17-2010, 12:22 PM
kitcarbp's Avatar
kitcarbp kitcarbp is offline
Cobra Make, Engine: West Coast, 460 Ford Racing Crate w/ TREMEC TKO 600
Hey Tom, Thanks for the tips, the adapter you are speaking of is the 90 degree adapter that just angles the oil filter towards the front of the engine and I too have been using one from Ford Racing since I first fired up the motor and the o-rings work real well with ZERO leaks for me so far. Yes it mounts in a similar way with a larger hollow bolt sealed, with o-rings that I purchased from Ford so I know its the right one and should seal. What I am now installing is an actual oil cooler that also rotates the filter forward, but will now will use an oil filter (FL-820S) with larger diameter Metric threads (M22) instead of the FL-1A 3/4"-16 threads, I guess Ford designed it like that for better oil flow exiting the filter (FL-820S) back through the cooler and into the sump, less pumping loss from a lower restriction I guess. This Explorer cooler is a much better design than those used on the early 90's F series truck 460's which were not very durable (prone to leaks and mixing fluids) from what I have read.
I 'll post some pics when I get the plumbing installed and running and post my oil temp observations. I am expecting to see faster oil warm-ups and should not see peak temp swings if the theory holds true, I'm measuring sump temps at the drain plug so'ill see the coolers effectiveness quickly if this works .
"...some assembly required, ages 8 and up...... well that took longer than expected......
