Old 11-19-2010, 06:24 AM
dcdoug's Avatar
dcdoug dcdoug is offline
Originally Posted by azfordman View Post
Rick, I take it the base plate is in my picture with the 8 and 6 stamped into it, correct? Where is this wire clip that is supposed to be under the rotor? Someone else had mentioned welding the slots.....are these slots on the underside of the base plate? I will get out and try to pull this apart tomorrow. I appreciate the input! Mark
The wire clip is down in the rotor housing hole and is a bit of a pain to get out. I had to mess around with it with needle nose pliers for a while to get it out. Remove it, unscrew everything, and then you will see that the bottom plate that everything is bolted to is removable and beneath that is the advance mechanism.
Here is an article that might be useful. It's for slightly older model Ford distributors, but most of the principles should be the same.
http://www.mustangmonthly.com/techar.../photo_12.html
www.partskeeper.com
