Originally Posted by Earl J
Hello Bill,
Great job! I do have a question is this item for sale or rent? I’m also curious to know if it’s possible to add the other two holes to the tool so when one aligns the 2 existing holes with the tool, the placement of the third hole would be symmetrical instead of eyeballing the third hole to the 12 o’clock position going from carb to carb. Just a suggestion.
Thanks,
Earl,
In a perfect world we would assume the factory holes are all in the exact same position and they may well be, however I have seen other "factory parts" vary slightly. What you suggest could certainly be done but with the tools at my disposal I would have to cut a carb in half to properly locate the two factory holes. Unfortunatly I do not have a bunch of 48IDAs to sacrifice.
Fairly easy to locate the third hole at 12 and as I stated in the post below I do not think that the holes have to be exactly at the same Location.
Let me hear your thoughts.
