Get me the complete name on the customer that purchased the engine so that I can get the file. Do you know if it is a Polymer type material. Comp Cams had us using some of these and we had problems with some of them breaking. I will need to look up the information on the camshaft to see what gear we should put on it. I would chamge the
oil and maybe flush the
oil pan through the dist hole with diesel or some type of cleaner that will run any little parts of the gear out.
If you will send us the distributor we will get the gear replaced with one that should work fine for you and you can then re-install and be going again.
Thanks, Keith Craft
870-246-7460
