Do a search under
oil pressure fitting in superformance. I listed the part numbers you need which can be obtained at ACE hardware. If you have the pos push in connection that is your problem. In order to remove you will will need to take a 5/16" box end 12 pt wrench and cut a slit so you can remove without removing fuel pump. Once again do a search under spf and you will find a post listing details.
