Old 11-23-2010, 03:56 PM
madmaxx madmaxx is offline
The line is 3/16" tons of connections and ferrules. The tubing is actually pretty heavy duty compared to others I have seen. The only problem with 3/16 and smaller is they do not make the brass insert to put in the tubing, it is just to small. Assemble push tube in tight and square and tighten snugly. Start engine, if leaks tighten more. I did some testing (as usual) LOL, and cranked the crap out of it, tubing never cut but ferrel extruded out cap. Just snug and you will be go to go.
