I am using a hydraulic throwout bearing form a stock pontiac gto..going to a tremes 6 spd. After putting it together i dont see how there could be any issues?!!? i did change the bleed tube (which instead of it being a 6 inch hard tube that squirts fluid into the bellhousing for bleeding) to a stainless braid long line that reaches to the intake manifold. Super simple to bleed the clutch and handles a performance clutch and 600hp no prob.
Which tranny are you using? Maybe a foolproof fix would be a 5/8 wilwood hydraulic clutch( mounted next to the brake cyl), hard lined to a flex line next to the tranny and a hyd throwout. Run the bleed up to the engine bay and it doesnt get any simpler.
If you need some pics i would be glad to email you.
chris.
