Old 11-23-2010, 11:04 PM
boxhead's Avatar
boxhead boxhead is offline
Originally Posted by DaveW View Post
Box,
Mine is new round chassis, not sure on finished weight, but Ian suggested it will be about 1150 with a 48/52 distribution, so similar, but i think the wheel travel to shock ratio is different.
Us fat bastards will have to get together, sounds like we could be called the ballast brothers.
Toperformance is pretty adament that 450 is way too stiff based on the dimensions and weights i gave him.
He is suggesting an eibach or kings sports single rate spring at about 375 to 400 lb, and rr at 450, which sounds similar too yours,
If i can ask so boldly, maybe i shouldn't, but whats your rear feel like........
Dave
I already told you I am a fat bastard so it is round.
Oh do you mean ride wise in the Cobra?
I think it is too soft, it moves up and down alot on undulating roads.
I do also have a failed rear shock so will be looking to replace (Spax) may look at EVO or Koni.
My springs are single rate kings, when I get home I will take a look at invoice as I really cant remember exact spring rates.
I would like lighter front springs in mine and heavier rears (rears only 25 lb heavier I think) and add a sway bar to the back.
Cruising in 5th
