Originally Posted by Jerry Clayton
you need to correct the washers on the bolts in your pressure plate and also why aren't you using the dowel pins for where the pp joins the flywheel??
And your quick jacks
My overpriced Centerforce aluminum flywheel had no dowels -- loctited ARP shouldered bolts though. I do use the split lock washers on the starter motor and, as you can see from the photo, I have to retighten them ever few months.
