  #43 (permalink)
Old 11-24-2010, 05:37 PM
Jerry Clayton's Avatar
Jerry Clayton Jerry Clayton is offline
Patrick
looking at your pics---why don't you use a lock nut on your starter bolts???? oh, thats right---you don't even have any nuts for them----
And a pointer that you should write on the garage wall---when tightening the starter bolts on an FE engine---use a long extension for a 3/8 drive with a 9/16 socket and tighten from the right FRONT side of the block(forward of the motor mount)you can easily put 80 ft pounds torque if you want--
and don't use the arp bolts--there are specific bolts for the starter
