  #47 (permalink)
Old 11-24-2010, 06:02 PM
Jerry Clayton's Avatar
Jerry Clayton Jerry Clayton is offline
they aren't any good for anything that needs much more than you can do with screw driver amount of torque--there are some wobble joints that are very good
In your pic it doesn't look like you have any nuts on the starter bolts on your scattershield---if not---
when and if you have it out of the car, weld some metal lock nuts to it so the bolts can screw directly in just like a staok bell housing---and you need the locating ring and the shanked starter bolts to insure the starter is lined up in the correct relationship with the flywheel
