Treed, you're already up to about $25,000, assuming wheels and tires and outside paint job. I drive mine alot. The efi 5.0 is plenty and if you want more add a cam and injectors. The 351 buildup will run you about $4000.00 and the carb setup doesn't always start after sitting up. All those other suspension options are great for the track but the regular rear end and sway bar is plenty. After all the car is about 2200 lbs. with you in it. Good luck!
