  #26 (permalink)
Old 11-24-2010, 10:29 PM
David Kirkham's Avatar
David Kirkham David Kirkham is offline
Original Shelby Owner
RestoCreations
Answers below:
1. Pedal assembly
How much of the assembly do you want? Do you want the reservoirs, reservoir lines? Do you want original type pedals or do you want Kirkham pedals?
2. Master cylinders
What sizes?
3. Hydraulic clutch
Do you want our hydraulic throw out bearing assembly, or an original type one? What transmission?
4. Reservoirs
Billet aluminum? Original steel type?
5. Carpet
Nylon or wool?
6. Passenger seat
Yes, we have seats in stock. They are $900 each. They are very high quality. We even use leather for the welting. The pleats are true tuck-and-roll, not just sewn down over foam. They are quite nice. Just for this thread I'll let one go for $700
7. E-brake boot
Original cars don't have them.
8. Radiator
We don't have any scratch and dent ones in stock. I think we are out of radiators right now. I'll check.
9. Radiator tubes and hoses
Yes, I saw a dinged set today. $300 retail--$150.
10. Header tubes or headers
Stainless or steel?
11. Sidepipes
stainless or steel?
12. 427 FE engine intake manifold plate
Not sure what you are referring to? I did take down several intake manifolds today. We even have a 1965 Medium Riser dual quad intake I found.
13. Engine pulleys
We have some harmonic balancer pulleys. $100 retail. $25 until they are gone. I think we have 4 or 5. They are from Keith Craft. They fit a Big Block Chevy (don't worry). They need to be slightly slotted to fit an FE. We have used several of them, but finally ended up making our own matched set.
We also have some alternator pulleys--I think 3. $10 each
14. Differential vent and reservoir
We use our brake cans for this. A brake can is $100 retail. We have a few scratch and dents. Maybe 2 or 3. I'll let them go for $25 each.
15. Driveshaft
I'll post the part numbers.
16. Driveshaft safety loop
I sold 16 of these today! LOL. $125 retail. $75. There are only 3 left. It is a complicated piece--not just a "U" bolt.
17 Exterior mirror
Which mirror do you want?
18 Visors
I doubt we have any scratch and dents.
19. Wind wings
I don't think we have any scratch and dents...but...not that I think about it...
We do have a LOT of extra hardware. I'll check on this. You can always cut them out from plexiglass and then use the hardware. I'll post drawings if you are interested.
20. Shifter
Which shifter? Which transmission?
21. Throttle linkage
$125 retail. I'll let one go for $75. Again, it is a complicated part.
22. Vent kit
I don't think we have any scratch and dents. I'll have to check.
Thanks!
David
