You are best to assemble on the ground, the center main hoop then the hoop with the hinge goes to the back towards window.
Don't forget to run the hoops through the cloth strap in center, they are supports.
Once it is together you will need a friend to help put on the car , one person on either side. Be sure to put a thick cloth on the area around the door and fender to avoids any scratches.
It goes on fairly easily and is functional although the inside of the car does get stuffy.
I would suggest putting some weathersrtripping or 3m tape on the rear as it will scuff the paint as it flutters going down the highway.
I found this out the first time I used it,however I was able to buff them out and now I have weatherstripping on the top back there.
