I think that the safer (and perhaps easier) thing to do is grind the entire area with cracks away, then cover with a couple layers of mat. Finally, after a full cure, shape the new glass down before using a final finish of epoxy filler.
That process will probably end up with something with a more stable base. I worry about "spot" fixing showing up in the paint eventually.
