These are pictures of prototype 427 S/C head tubes. These head tubes are not completely welded and will need some tweaking and welding to finish them up. Tubes are made from mild steel.
Head tubes retail $1,000. I'll let these go for $250. Please see the below description. They need work.
SOLD
Below:
Left head tubes. Notice the "hole" between head tube #5 and #6. That is where the steering shaft goes through the pipes on the original car. The #5 tube is to the right in the below photo.
The $5 tube is to the left in the below photo.
#7 and #8 are do not have the flanges welded to the tube. They are only tacked into place.
#7 only has the tube tacked together. It is not welded together.
The flange on #7 is 3/16-1/4" of an inch away from the flange. The tube will have to be stretched and tweaked to fit.
The following 2 pictures are of the right side. The right side head tubes are quite short--just like an original car.
