Old 11-27-2010, 07:56 PM
Xack's Avatar
Xack Xack is offline
Cobra Make, Engine: West Coast Dreams
Default Lokar is a good choice
This post was done almost a year ago. But I have .02 cents worth to spare.
The item WCC sells you is a push pedal cable. I promptly replaced it with a Lokar pull cable and the chrome steel gas pedal mounted to the vertical firewall in the foot box. I aranged the lever to pull the cable down, vertically and not through the firewall. The cable goes up and throught the fiberglass above the frame and behind the engine. This is a pull type with springs will keep the throttle from being stuck wide open like WCC's design may do.
Good Luck,
