  #125 (permalink)
Old 11-27-2010, 08:33 PM
LMH's Avatar
LMH LMH is offline
Originally Posted by David Kirkham View Post
While coming back from moving the Coupe SPF die I found this
We just pulled this differential out of a customers car and exchanged it. The differential was leaking a bit (it is 10 years old--it is out of the NYC 911 car we donated to the NYU Hospital at Ground Zero. Can you guys believe it has been 10 years!) It was also make a clunking noise as the clutches grabbed and let go. We just replaced it. We don't have time to figure out what is wrong. The differential unit is a Dana Power Lock. They are not that expensive to rebuild.
Retail $5,000. Today $2,500 I'll even throw in the upper mounts.
3:31 Ratio
Hmmmm, I'm thinking!
Alba gu brąth
