Roller set up is cheap. 16 ford racing hydraulic lifters $110.00, Camshaft price is the same regardless. so the difference between a roller and flat tappet is $60.00 more for the lifters. No lash adjustement, no break in etc. no phosphourous/
zinc additive. I had a 1995 302 completely stock long block with edlebrock performer heads, edlebrock rpm manifold, holley carb and it dyoned 302 hp at rear wheels. I beat the car sheetless and never thought twice about it. total cost including all new edelbrock components was about $3500. Last checked it had over 30K miles of abuse including a tons of track time. If you want to cheat the system on zero to 60mph times, get a 3.92 rear end ratio or higher. True above 100mph it started flating out on acceleration but the race was long over before then.
Originally Posted by redmt
You are taking into assumption that I "need" to have a roller set-up. So many of these engines are overbuilt for the intended purpose. Thousands are spent just so bragging rights can be had. A flat tappet hydraulic cam will suit my purposes just fine.
