OK, now we're getting somewhere.
Tip: In future post in 'Small Block Talk' forum. You'll get more help 'cause those guys almost never look at the FE forum.
You don't say if track car or street only-just that you want max HP without big compression. At 11:1 on 93, you can easily and comfortably get 550 to 575. I would use 255's or something in the 235cc range, with 2.08's and 1.60's, an hydraulic roller around 245 deg and .660" lift and a 900+ cfm Holley or even a 1050 Dominator-if not in a Cobra.
Brent Lykins on here specializes in good Windsor builds.
The more info you give the more effective advice you'll get.
Chas.
