  #25 (permalink)
Old 12-02-2010, 04:12 PM
RET_COP's Avatar
RET_COP RET_COP is offline
Cobra Make, Engine: Fordstroker 408w custom solid roller-Craft ported Brodix 17*heads-CFM ported Vic Jr. intake-1 3/4 primaries- 575hp-TKO-600RR Liberty upgrade- -Moser 8.8 trutrac-McLeod Street Extreme--QA-1-Wilwood brakes, Classic Chambered 3" Cobrapacks, Avon's
Paul, If you use a tubing cutter it won't scatter metal filings in the tube. Then hold one piece vertical ( cut end down) and pull a small rat tail file toward the ground taking the lip off. Holding it in the same position with a pan underneath pour some isopropyl alcohol through from the top which will flush and clean it for weld prep. Do the same to the other piece.
Lou
Lou
