  #21 (permalink)
Old 12-02-2010, 07:42 PM
Barry_R Barry_R is offline
I've set up several of the TWM systems on FE engines using the dyno as a starting point. We used either FAST or Big Stuff 3 modules and laptop computers. The engine dyno can get steady state fuel curves and WOT tuning established using wide band O2 data. But it cannot do transitionals and variable load.
As mentioned - tuning an EFI systeem is best handled on a chassis dyno for establishing part throttle and transitional fuel curves. Second best is getting a knowledgable helper to monitor and adjust things with a laptop in the passenger seat. Thirs best is to take short rides and use the system's data logging capability to record what happened. The make an adjustment and try again.
I have no experience with the latest "self learning" systems. Not really sure if I "believe" in the media hype....
Survival Motorsports
"I can do that....."
Engine Masters Challenge Entries
91 octane - single 4bbl - mufflers
2008 - 429 cid FE HR - 675HP
2007 - 429 cid FE MR - 659HP
2006 - 434 cid FE MR - 678HP
2005 - 505 cid FE MR - 752HP
