Old 12-03-2010, 01:37 PM
Mark IV Mark IV is offline
Senile Club Cobra Member
This is an installer item, SPF does not supply the slave cylinder and rod. many use the cylinder for a Ford Probe. I have a part number somewhere. You can find the rod at NAPA, it will have a rounded end to sit in the cylinder piston and a threaded end.
The return spring is also an installer item, different guys use different springs but I do recommend a return spring. One of my customers has a "hardware store assortment" spring that attaches to the TO arm at the outer edge visa a hole and then anchors on the bleeder nipple on the slave cylinder. You can use a pretty stiff spring as you cannot tell the difference on the pedal from a soft to very stiff.
You may need to remove the slave cylinder piston and cut down the internal spring to allow the piston to retract enough for complete disengagement.
rick@autoventureusa.net
