STEERING COLUMN!!!
PHOTOS UPDATED!
We have 5 of these.
4 SOLD
You have been waiting so I went and found one. (The tops are still buried).
Includes
main steering shaft, stainless (31 1/2 inches long) $150
steering wheel nut $25
steering wheel hub $125
steering column $150
lower support bearing $50
Hub will accept original steering wheel bolt hole pattern.
The engine end of the main shaft is a "Double-D." We have the original style 3/4 48 spline on the engine side as well (please add $15 for the original end).
Retail $500
Today $250
Steering column tube fits the standard VW turn signal switch
Engine side of the shaft is turned to accept a 3/4 bearing.
Lower bearing support for foot box.
Close up of the lower bearing support which bolts to the foot box.
