Bruce Collins
Cleveland, Ohio
FFR 6795
Ford 390 iron block bored .030 over & stroked to 447
Vintage expansion tank
Edelbrock RPM Performer heads
Scat 4.25" Crank
Holley 750DP Carb
Manual choke
Scat H-beam rods (chevy)
Diamond flat top pistons
Comp 294s flat tappet cam
Erson roller rockers
Romec balancer
Edelbrock intake
Moroso T-pan
10.5 compression ratio
Dyno at 490 HP at 5200/510 ft lb torque at 4200
15" Vintage pin drive wheels
Goodyear 295R15's in rear, 235R15's in front
RAM flywheel and clutch
Quicktime bell housing
Tremec T-56
Ford 8.8 pumpkin, IRS with 3.55:1 ratio
Drive Shaft Safety Hoop
Twin chrome roll bars
Halon fire extinguisher
Black powder coated aluminum panels
Aeromotive A1000 fuel pump
Aeromotive firewall regulator
Stainless Steel -6 AN fuel lines
Stainless Steel brake lines
Polished roll bar trim rings
Polished seat belt bezels
Wood steering wheel
Vintage heater
Cobra heat seat heaters
Kirkey seats
Lucas style wipers
Black Bently carpet
Chrome 100 amp 1 wire alternator
3M clear splats
