Rings rotate. Factual data is a dangerous thing. When I ran Speed-Pro we had lab data that proved it. Use radioactive pellets embedded in rings to see how fast on the dyno. Turned out to be around 10-12RPM, but completely at random - sometimes they reversed themselves.
Movement was just considered to be due to variations in bore finish and profile. A poor hone job can have deep grooves in one direction and shallow ones in the other - that'll cause the rings to spin rapidly in the grooves and they will wear out very quickly. Gaps lining up is usually bad bore profile - an irregularity in cylindrical shape.
Survival Motorsports
"I can do that....."
Engine Masters Challenge Entries
91 octane - single 4bbl - mufflers
2008 - 429 cid FE HR - 675HP
2007 - 429 cid FE MR - 659HP
2006 - 434 cid FE MR - 678HP
2005 - 505 cid FE MR - 752HP
