Dan,
Amazing, but as usual adding your unknowing 2-cents out of the clear but snowy sky. Why should I Not be surprised? Taken over the "Fling" yet? Or as I now understand it, the London Cobra show.
Ed, I assume you made it home safely with the weather closing in. Just so you know, it is not the Tank nor the a.r.e. fitting that is dripping gas! It's actually the seal/fitting right behind the A.R.E. fitting, much like "Banjo Seal" as on brake line. I will put on a new pressure washer, presuming that will take care of that.,
Final buffing, fix the thin fiberglass on the trunk, change the tranny to a new T-5, put shorter bolts in the roll-bar, and wait for Spring!
