  #786 (permalink)
Old 12-12-2010, 11:02 PM
tkb289's Avatar
tkb289 tkb289 is offline
Originally Posted by tkb289 View Post
David,
Will this shifter work on a TKO 600?
If not, can it be modified, or made to work on the TKO 600 with some kind of an adapter?
Thanks.
- Tim
Originally Posted by David Kirkham View Post
As is, it will not work on a Tremec. However, it can be modified. We have done it several times. You just have to cut the bottom off and bolt or weld a Tremec adapter on.
David
David,
In that case, can you put one in my box for now and I'll check with Mike tomorrow to see if we can use it. Thanks!
- Tim
289 FIA --- ERA 2136
Build Log:
http://www.clubcobra.com/forums/era-...build-log.html
