Depending on the type of ignition system your running it could be related as well. Timing and ignition can sometimes mimick the fuel issues as well. Not likely but just dont rule it out.
Put some cardboard in front of the radiator and get the motor hot...you might be able to reproduce the problem in the garage.
" If it wont break em loose in 3rd gear, it aint enough power "
