Old 12-15-2010, 10:45 PM
Keithc8 Keithc8 is offline
Default New Polished Kirkham Bargain, customer loss
I have a finished Kirkham that has been done about 5 months. The car has 250 test miles on the all aluminum Pond side iler block with the new Pond SK Medium Riser heads that we designed. This is a 482C.I. new aluminum engine that idles on 700 rpms, starts well and will cruise at 2000 rpms but still makes 628HP and about 620 ft/lbs of torque. The Car is a Kirkham fully loaded car with out the stainless chassi or larger fuel tank but about everything else. Our install is second to none with all matching wiring covering as used by Kirkham. All engine parts are aluminum, plished or black. The engine lokks great under the hood.
Has the Goodyear Bill Boards brand new ready to go with Quicktime bell housing, McCloed clutch and pressure plate with TKO-600 transmission. Just a top notch build top to bottom. Has the stainless steel side pipes as well with Kirkham turkey pan and Kirkham Billet coolant tank as well. This is one of the best Kirkhams on the market right now and because I recieved a 10,000.00 deposit on the car for a saling price of 110,000.00 without him finishing the deal in the contracted time it is now for sale at 100,000.00 . There is no way to duplicate the car at this price and would be hard to do at the 110,000.00 price with all of the parts used in the engine build and car alone.
The enigne alone has 4340 steel crank, H-beam rods, solid roller street grind with oiler Comp Cams lifters, the high dollar T&D rockers, Edelbrock aluminum water pump, billet pulleys and brackets. Many Kirkham extras such as distributor hold down, throttle spring return bracket, Kirkham custom billet clutch linkage.
This will be a buy for someone that wants a nice Polished Kirkham with the polished stainless side pipes with the Goodyear Bill Boards. The car has been set down and ride hieghts set with 4 wheel alignment done. Has won the two car shows that it has been taken to. Always draws a crowd and best of all it has been built by Keith Craft Performance Engines and the Kirkhams, does not get much better than that. Will come with a new MSO from Kirkham with your name on it because it is a new car. Can be seen at www.keithcraft.com
Thanks, Keith Craft 870-246-7460
Keith C
