Originally Posted by Three Peaks
David,
I am going to have to go ahead and get a set of these mounts also while you are being generous....
Do the upper control arms include bushings? How do you connect them to the uprights- threaded bushing connector for adjustment or a welded connection?
I have other questions, but I'll wait until the scratch and dent sale is over so I don't drive Steve and you crazy.......
Bob
The Jag mounts come with bushings. The control arm do not. They are connected to the upright with a 3/4-16 rod end. The rod end has bushings in it that reduce the 3/4 hole to 1/2 inch. A 1/2 inch bolt then holds it to the upright.
David
