T-5
Hi Gary,
A T-5's life is about the drivers technique (no power shifting), horsepower/torque & weight of the car. Let's face it, a Cobra usually weighs less than 2600 lbs. With a smooth driver the T-5 Z is a great gearbox if you're nice. If you on kill, expect it to die with a good shot of abuse....
Remember, no powershifting or sidestepping the clutch and you should enjoy it for years...
Oh last note, do not use a heavy performance clutch. I would recommend a King Cobra clutch. That will decrease the impact of a hard grabbing clutch.
Originally Posted by hinoonaz
Hi Mike
Can the new t5 handle the torque though. I am not hard on the trans otherwise mine would have blown up long ago. Of course if synchros were better , abuse would result to a small degree.
thxs gary
Forte's Parts Connection
40 Pearl St
Framingham, Ma. 01702
fortesparts.com
508 875 0016
In 1993 Mike made the first conversion of a Ford Tremec to GM 5-speed. It bolts to stock bellhousings w/out an adapter. The FE Tremec, the Mustang adjustable quadrant are originals from Mike.
One of 12 Tremec Elite Distributors worldwide for: T-5, T-56 Magnum & TKO-500 & TKO-600 ,Midshifter, Frt shifter, offset Vette shifter.
Est: 1981 selling performance parts to build your dream car...
